TENDRIL Posted May 1, 2012 Report Share Posted May 1, 2012 so i have the chance to buy a 1972 510 wagon auto, has been parked for a couple years the owner parked it because it started smoking so he believes the rings have gone bad, he started to take it apart but only got as far as taking the manifolds off, and the valve cover... im looking to get this for my mother, but im also moving to AZ on the 12th so im wondering if i can fix this within a week or so and if this is the rings where would be the cheapest to find them.. unless someone on here has some does this sound like worn rings. or a head gasket.. and can this be done fairly quickly? im going to look at it 2maro.. edit- "never did a compression test. it was a blueish smoke and it was smoking pretty good on the freeway and than i parked it" -owner Link to comment
datzenmike Posted May 1, 2012 Report Share Posted May 1, 2012 OK.... if it was a gasket there's a good chance that coolant has leaked down into the cylinder and will have rusted after two years. The guy probably wouldn't care if you took the head off.... it would have to come off anyway. You could look at the cylinder wear while you're there. Rings? Well expect the worst and go from there. I've done a few hone and re-ring without checking for wear. They lasted about 8 months because I should have over bored and got new pistons and rings. Yes you could do it in a week if you devote 7 days to it. Hard to do it with the motor in. Myself, I would pass on it. Link to comment
TENDRIL Posted May 1, 2012 Author Report Share Posted May 1, 2012 Well I did plan on pulling the motor, what kind of wear do I look for on the piston walls, if it were taken out it would still take a full 7 days ? Link to comment
lil89ram50 Posted May 1, 2012 Report Share Posted May 1, 2012 probable be cheaper to get a used motor. guys are always practicaly giving them away here. sometimes 100 bux if its cheap, and in decent shape, get it on the road Link to comment
