beenjamin Posted April 20, 2012 Report Share Posted April 20, 2012 What transmissions will fit a KA24de engine? and what would be the most likely to fit in a b210? Quote Link to comment
datzenmike Posted April 20, 2012 Report Share Posted April 20, 2012 FS5W71C from a 240sx or D21 truck. The FS5W71B from a NAPS Z engine 720 truck or S110 200sx should also fit but the 'C' tranny is stronger. Neither is going to fit the B-210. ... but the B-210 could be made to fit the transmission. The 240sx tranny is the longest but both will require the driveshaft to be shortened. Not sure if the B-210 spline will work but the U joints in it are non removable anyway so make a new one. The H-145 rear end won't survive the DE for long so think about one from a later '77-'79 S10 200sx. It had an H-165 with leaf springs. Best would be thew rear assembly from an '82-'83 S110 200sx... It had an H-190 (just like the trucks) but coil spring and link suspension. Just grind off all that and weld spring perches on for your leaf springs. The width should be comparable. Oh yeah... they had rear disc brakes. A DE in a B-210 is like a SBC in a 510, but I want to see this completed!!!! 1 Quote Link to comment
beenjamin Posted April 20, 2012 Author Report Share Posted April 20, 2012 Thankyou very much Quote Link to comment
