5 Speed Transmissions for sale - have 3 - San Diego
  • Replies 8
I was told the first trans against the wall came out of a 620 pickup like mine, but it didn't. From doing the research on Ratsun it appears they are all out of a Z. They all have the same identical attributes. The only reason the one against the wall has shifter ears that look different is because they are taped over with duct tape. I've never used or installed any of them as I am looking for a wide ratio trans with a lower first gear to match my 4:11 rear diff on my King Cab . Earlier 620 not a King Cab can use these mid ratio trans much easier because they have a higher rear diff ratio.
  • 2 weeks later...
