jun Posted March 18, 2012 Report Share Posted March 18, 2012 As title states. Just did an alt upgrade on my L16 and need the L20 alt bracket to fit the larger alternator (larger bolt hole diameter, I want to say M10?) Would have to be shipped to Los Angeles. Would consider picking it up if you're local. If you have one, do let me know. Thanks! Jun Link to comment
crackerjack69 Posted March 19, 2012 Report Share Posted March 19, 2012 I think I have a few of these Jun. I will check in the morning. Link to comment
jun Posted March 19, 2012 Author Report Share Posted March 19, 2012 Thanks brother, let me know! Link to comment
crackerjack69 Posted March 20, 2012 Report Share Posted March 20, 2012 $15 shipped. Paypal is chrischilds@rocketmail.com Link to comment
jun Posted March 20, 2012 Author Report Share Posted March 20, 2012 Sent! Thanks Chris. Let me know when you've shipped it. Link to comment
banzai510(hainz) Posted March 20, 2012 Report Share Posted March 20, 2012 Theres kind of a proplem with that. L16s use the smaller bolts still on the block 2 bolts that I have seen, and the L18/20 mounts use the bigger bolts in the block 3 bolts. So I know your not going to drill out a L16 block.So it will still wiggle with the smaller bolt on a bigger dia hole. However one can have the stock mount drilled out to 3/8 from front to back and use a long bolt with the last inch or so sticking out with threads. the one shown is most like a truck type. Link to comment
crackerjack69 Posted March 20, 2012 Report Share Posted March 20, 2012 Ya, the L20 is different. Figured he specified needing L20 one for a reason...? Link to comment
jun Posted March 20, 2012 Author Report Share Posted March 20, 2012 Hainz, thanks for the clarification. Sorry Chris, this isn't going to work for me. Can you return that payment? I'll PM you. Link to comment
banzai510(hainz) Posted March 20, 2012 Report Share Posted March 20, 2012 to be sure you have to measure but maybe if it was a late import L16 it COULD have the bigger holes. But Im wongin it on this one. But all the common USA imported l16s that were orginal in the car truck were the small hole type. unless Jun could post a photo of yours with mesuring tape across the hole dia. Link to comment
jun Posted March 20, 2012 Author Report Share Posted March 20, 2012 Hainz, mine indeed has the smaller holes, 2 bolt. What I think I'll do is just get/fab some sleeves to better mate the big alt hole to the smaller M8 bolt. I read somewhere that I need a L20 alt bracket, I guess this isn't the case. Chris, I do thank you for your prompt replies! Thanks both of you, I'll figure something out shortly. Link to comment
