DISLEXICDIME Posted April 25, 2008 Report Share Posted April 25, 2008 me and my cousin where looking at the 2 l16's and l20's lined up in my garage. Then we had a thought what if we putt a l20 crank in an l16 and made a stroker l16. any one tried this Quote Link to comment
datsunaholic Posted April 25, 2008 Report Share Posted April 25, 2008 The big issue is the main bearings are smaller in the L16, so either the block would have to be linebored to use the L20B bearings or the crank main journals turned down. The other issue is the increased stroke exceeds the block deck of the L16. Shorter rods will reduce that, but that increases side load on the pistons and will wear the bores out faster. There's a reason the L20B was built with a taller deck. Quote Link to comment
DISLEXICDIME Posted April 25, 2008 Author Report Share Posted April 25, 2008 o i see thats good to know Quote Link to comment
b210in Posted April 25, 2008 Report Share Posted April 25, 2008 too much work, just use the l20b Quote Link to comment
DISLEXICDIME Posted April 25, 2008 Author Report Share Posted April 25, 2008 it don't matter about the work . but i did find out something neat today the l16 i have is one from japan and it is a l18 destroked to an l16 for higher revving so maybe i will just play with the l16 Quote Link to comment
