rsdaumer Posted March 8, 2012 Report Share Posted March 8, 2012 Hey everyone. Getting ready to move to baton rouge next week and trying to get my 620 up to the task. it runs fine as long as you dont have the lights on, then the voltage drops dramatically at the battery. i changed the voltage regulator but that hasnt fixed the problem. there's an aftermarket radio the PO installed but its not hooked up (he had it wired to the power wire for the hazard lights, wtf?) and he hooked up trailer wires to the back of the truck so im gonna check if they are short circuiting or anything. going to take the alternator to auto zone to have them test it. anyone else have any ideas? i did some research on here but 'really find anything. i appreciate the constant help guys! Russ Quote Link to comment
banzai510(hainz) Posted March 8, 2012 Report Share Posted March 8, 2012 take the alternator and tell them to LOAD test it. I know the NAPA close to me has a LOad tester soemplaces just ck the voltage but most put a load on there now but ask. First off if you got say arounds 13.5 to say 14.3 volts your volt reg is good. But put on the lights .or wipers or just the heater fan and see it dropping then usually its the alternator getting weak. order the correct alternator for your year truck so you know its a perfect fit Quote Link to comment
rsdaumer Posted March 8, 2012 Author Report Share Posted March 8, 2012 right now with the lights off it stays steady at 12.10 volts, with the lights on it drops till it dies Quote Link to comment
banzai510(hainz) Posted March 8, 2012 Report Share Posted March 8, 2012 Dude try soem thing else that isnt much of a draw. try running it with nothing on and read the voltage first then pick soemthing small like level one on the heater. or just maybe hitting the brake light on and see what the voltage is on/off its a simple sytem. Unless you got a blown fuse soemwhere it might not even be charging at all. Quote Link to comment
