L20b
ddrum
Ok, recently the L16 in my 620 seized. I found an L20b out of a 1980 720. This is my first time removing an engine, so my question is from which part of the engine should i pull it out, it doesnt have the tranny anymore and i really need to take it out by today, any help would be greatly appreciated. I did research
Thanks, Erick
  • Replies 4
http://community.rat...g-my-510-motor/ <<< watch
I assume this is a standard??? Best to remove the motor and trans together. So have front end up high so the tailstock can drop down when tilting the motor up to lift out.
1/ Remove battery cables from battery, ground cable from the head.
Drain cooling system and remove rad.
Drain oil.
Unbolt exhaust down pipe from manifold.
Remove the two heater hoses, one from the head and one from the lower rad inlet to the block. Tie out of way
Remove air filter housing and cover the carb so shit does not get in there.
Disconnect the throttle cable, tie out of way. Tie out of way
Disconnect the large vacuum hose to the brake booster. Tie out of way
Disconnect the distributor and temp sender wires and tie out of way.
Unplug the (red) idle cut solenoid and (blue) auto choke heater wires.
Remove the vacuum hose to the charcoal canister.
If equipped with air pump disconnect the hose to the filter on the fender.
Disconnect the fuel line at the inlet to the pump and tie out of way. Gas may siphon so watch it.
Disconnect the fuel return line (if equipped)
Disconnect the alt. wiring... what's that ? sparks?? Now go back to the first thing (1/) and do it!
Unbolt starter and tie out of way or remove wiring and remove for more room.
Remove oil pressure sender wire.
If you feel up to it and just want to remove the motor ignore the rest.
____________________________________________________
Remove driveshaft.
Remove shifter
Drain transmission
Disconnect reverse light wiring
Disconnect the speedo cable
Unbolt slave from transmission and wire up out of way. Tape or tie the pushrod so fluid does not push it out.
Support transmission
Unbolt the rear tranny mounts.
Unbolt the motor mounts
Lift out checking for something obvious that I forgot like a small ground strap from the back of the exhaust manifold to the firewall..
Read ^^^^ then go to google and type "help pulling my motor - Ratsun" and go from there
