DISLEXICDIME Posted March 8, 2012 Report Share Posted March 8, 2012 Did 720's come with a warning chime that tells you if you leave the lights on? if so where is it i need to hook it back up. :blink: Quote Link to comment
Skulptr Posted March 8, 2012 Report Share Posted March 8, 2012 open driver door, pull black button/switch at the bottom of the door jamb on the cab. pull it out, there should be 3 wires behind it. 2 are for the lights, the 3rd for the chime. you can also access it from behind the interior panel from the inside by the floor just inside from that switch. found mine in there disconnected. the bell is extremely annoying, but if it stops her from doing it than that would be better than a dead battery. its a flat spade connector Quote Link to comment
DISLEXICDIME Posted March 8, 2012 Author Report Share Posted March 8, 2012 sweet thanks Quote Link to comment
