ofg Posted March 7, 2012 Report Share Posted March 7, 2012 Alright, probably a silly question. How do you get the intake manifold off a14 engine? I have removed all the bolts from the top, including the 2 in the middle where the heat flap thing is. I also found the 2 bolts under the carb platform next to the heat flap thing. Are there any more? My manifold is plumb stuck, not budging. Thanks! 1 Quote Link to comment
RedBanner Posted March 7, 2012 Report Share Posted March 7, 2012 Both the manifolds come off to gether mang. 1 Quote Link to comment
Eagle_Adam Posted March 7, 2012 Report Share Posted March 7, 2012 if its like an L series you will find bolts above and below the mani that go into the block that clamp the manifolds on Quote Link to comment
RedBanner Posted March 7, 2012 Report Share Posted March 7, 2012 The manis are bolted together, easier to see with out a shroud, they share bolts too like the lseries, and the gasket is shared so just pull em both 1 Quote Link to comment
Eagle_Adam Posted March 7, 2012 Report Share Posted March 7, 2012 Pics are worth 1000 words +1 1 Quote Link to comment
ofg Posted March 8, 2012 Author Report Share Posted March 8, 2012 Thanks guys. I got em pulled. Now I'm lookin to replace them with something better. Will post pics in later am. Quote Link to comment
