Phlebmaster Posted April 22, 2008 Report Share Posted April 22, 2008 I need a set of L20 rocker arms to put into my L16 A87 head. I am placing an L20 cam into my L16 head (thanks Brian) and I have to replace the rockers to match the cam. Almost forgot!!:eek: I am also going to have my intake valve ports enlarged slightly. I hope to have it done by June for the Canby show. :cool: Please let me know if you have an inexpensive spare set. Thank you for your help!!:D Aaron Link to comment
hang_510 Posted April 22, 2008 Report Share Posted April 22, 2008 your welcome. i may have a good used set that was once associated w/one of the cams (cant tell now but its where i got em) keep the lash caps you have, dunno if i have a matched set of those 1 Link to comment
Phlebmaster Posted April 22, 2008 Author Report Share Posted April 22, 2008 Thanks again Brian!!:D You are a life saver! Link to comment
hang_510 Posted April 22, 2008 Report Share Posted April 22, 2008 ideally youd want to match then to the same lobe as before, not possible now :rolleyes: youll need to spend some time setting it up correctly. i wasnt sure if yours were still there, id use those if so... time for another bag of popcorn ;) Link to comment
