TheGooner Posted February 28, 2012 Report Share Posted February 28, 2012 hey i have a 71 goon that was an automatic now a 4 speed. i just dropped an L18 in and have to deal with points for now till i can switch to ei later. just want to get it running. my problem is that the goon was wired for ei previousley (complete hack job..duck tape is not a good substitute for connectors and electrical tape) and have all the parts to get it running with points. im trying to get it wired up and i have the haynez for the wiring diagram but its like reading chinese for the first time i hate wiring. what i really need to know is what color wires go were on the distributor, coil, and ballast resistor. any help would be great. pictures of your wires would be better thanks. Quote Link to comment
banzai510(hainz) Posted February 28, 2012 Report Share Posted February 28, 2012 blk white (key ON)will go to the Ballast resistor otherside of ballast resisitor will go to the + side coil.This is usually the blk/green wire Blk/Blu wire is the 12volt(key in START) this will go to the +side coil. find wire that goes to the - side of coil or just make a wire from the main set of points to the - side of coil. That should be it You must use a POINT coil close to 1.6 ohms and the stock 1.6 ohm ballast resisitor. Make sure the dizzy has a good condensor also. if you got a volt meter you can ck for voltages. blk/wht with key ON blk/Blu with key in START (remove the starter wire so car dont turn over) call Pumpkin210 on ratsun here and he can get it going for you for a fee heres a drwng print this MOFO!!!! http://community.ratsun.net/topic/31830-510-whole-car-rewire-mess/ Quote Link to comment
TheGooner Posted February 29, 2012 Author Report Share Posted February 29, 2012 so the disributor has 2 male connection points. im assuming one is the condensor? what goes to the other? Quote Link to comment
banzai510(hainz) Posted February 29, 2012 Report Share Posted February 29, 2012 You only need one. the one with the bigger condensor on the side will be the main points. the other is the 2nd setwith a smaller condensor(I dont use them) Oh by the way it sounds like you have a L16 dual point dizzy and hopefully you have the matching timming mount to go with it. pictures of your wires would be better thanks. yeah why dont you do that and I will tell you where it goes Quote Link to comment
TheGooner Posted February 29, 2012 Author Report Share Posted February 29, 2012 1 Quote Link to comment
TheGooner Posted February 29, 2012 Author Report Share Posted February 29, 2012 im computer stupid that didnt work for the pics so i modified the posts Quote Link to comment
TheGooner Posted February 29, 2012 Author Report Share Posted February 29, 2012 <a href="http://s1159.photobucket.com/albums/p638/wats22jd/?action=view¤t=samsungpictures1659.jpg" target="_blank"><img src="http://i1159.photobucket.com/albums/p638/wats22jd/samsungpictures1659.jpg" border="0" alt="Photobucket"></a> <a href="http://s1159.photobucket.com/albums/p638/wats22jd/?action=view¤t=samsungpictures1656.jpg" target="_blank"><img src="http://i1159.photobucket.com/albums/p638/wats22jd/samsungpictures1656.jpg" border="0" alt="Photobucket"></a> <a href="http://s1159.photobucket.com/albums/p638/wats22jd/?action=view¤t=samsungpictures1655.jpg" target="_blank"><img src="http://i1159.photobucket.com/albums/p638/wats22jd/samsungpictures1655.jpg" border="0" alt="Photobucket"></a> Quote Link to comment
TheGooner Posted February 29, 2012 Author Report Share Posted February 29, 2012 hey banzai in the pictures i just want to clarify that that the yellow wire in the picture with black/red, black, and black/yellow, is yellow white. in the other picture with the black, black/white, and black/blue, is yellow/green Quote Link to comment
TheGooner Posted February 29, 2012 Author Report Share Posted February 29, 2012 :) appreciate the help Quote Link to comment
banzai510(hainz) Posted February 29, 2012 Report Share Posted February 29, 2012 yellow goes the the temp sender the yellw/blk goes under neath the brake distrubution junction Im busy at work but I told you what wires had power and whay not. go back to MY orginal reply and read carefully hook it up exactly and take photos and soemone will get back to you did you look at the color drwg in the link provided???????? Quote Link to comment
TheGooner Posted February 29, 2012 Author Report Share Posted February 29, 2012 thanks for the help brother. Quote Link to comment
