wagoon Posted February 10, 2012 Report Share Posted February 10, 2012 Can I just buy a Matchbox Dizzy at Autozone from a 78' or 79' 510 and use that to convert my points to EI? Will that work? Quote Link to comment
banzai510(hainz) Posted February 10, 2012 Report Share Posted February 10, 2012 Did you read olddatsuns.com in the tech section Jason Grays write up??????????????????????????On Electronic ignitions You have to right coil? You got the right pedastal for the dizzy. Does autozone sell the timming plate with the dizzy. a 78 or a remote EI. You have a EI Box ? did you try the test light trick? ppint dizzy are ez to figure out. Its just a mechanical switch. Quote Link to comment
wagoon Posted February 10, 2012 Author Report Share Posted February 10, 2012 Ok, I read the Jason Gray info...great info there. Pedistal, is that the stem? Quote Link to comment
banzai510(hainz) Posted February 10, 2012 Report Share Posted February 10, 2012 I cant make this any EZer for you Quote Link to comment
banzai510(hainz) Posted February 10, 2012 Report Share Posted February 10, 2012 fix the point dizzy first Quote Link to comment
