84 Nissan/Datsun Truck Posted January 2, 2012 Report Share Posted January 2, 2012 Thanks for all of the past help from Ratsun members. I found a 1986 ST Nissan 720 with Black interior and I have been transplanting most of it's interior into my 84 720. Currently I have my 1984 Nissan/Datsun 720 running well, I changed the fuel pump relay and ran a jumper wire and replaced water pump and thermostat. After changing the thermostat the heater is no longer working well. Does anyone have any suggestions. Currently I am now working on the replacing the interior and cluster from the 1986 ST 720. Also, how do you remove 1984 Nissan 720 Cluster and replave with cluster with tach and clock. So far I have removed the bezel and all of the screws around the cluster. The cluster will not come out far enough for me to disconnect speedometer cable and additional plug. All of your help is greatly appreciated. Thanks, John. Quote Link to comment
Sealik Posted January 3, 2012 Report Share Posted January 3, 2012 You need to reach underneath and remove the speedo cable before pulling the cluster out. It's a bitch...not much room, once it's 'forward' a bit...unplug the elec connections. Any 720 will have the elec wires to connect the clock and tach....they're just taped up and stuffed back on the main harness.... out of use You will need the resister plugged into the harness (behind coils) for the tach to function. What degree of thermostat did you replace the 'OE' one with? Quote Link to comment
datzenmike Posted January 3, 2012 Report Share Posted January 3, 2012 The new one may be stuck open now. It happens. Quote Link to comment
86 720 Posted January 4, 2012 Report Share Posted January 4, 2012 Thanks for all of the past help from Ratsun members. I found a 1986 ST Nissan 720 with Black interior and I have been transplanting most of it's interior into my 84 720. Currently I have my 1984 Nissan/Datsun 720 running well, I changed the fuel pump relay and ran a jumper wire and replaced water pump and thermostat. After changing the thermostat the heater is no longer working well. Does anyone have any suggestions. Currently I am now working on the replacing the interior and cluster from the 1986 ST 720. Also, how do you remove 1984 Nissan 720 Cluster and replave with cluster with tach and clock. So far I have removed the bezel and all of the screws around the cluster. The cluster will not come out far enough for me to disconnect speedometer cable and additional plug. All of your help is greatly appreciated. Thanks, John. Ya, that cluster is a bitch to remove. The end of the speedo cable has a knurled knob that needs to be "pinched and pulled" in order to be removed from the back of the cluster. You can see the connection on the back of the cluster from my build page: "clicky-click" As far as the heater, have you replaced any of the hoses leading to the heater core? I would recommend doing that since you are already replacing everything. Disconnect the heater core hoses and attach a hose to the inlet. If nothing comes out of the outlet, you have a blocked heater core. If the truck is not overheating, the thermostat is most likely working fine. 1 Quote Link to comment
84 Nissan/Datsun Truck Posted January 5, 2012 Author Report Share Posted January 5, 2012 Thanks for all of your past help. I finally removed the standard cluster from my 1984 720 and replaced the blank covers with a tach and clock from a salvaged 86 720 ST. Reassembly of the cluster was straight forward and the help from Ratsun members was greatly appreciated. Later when hooking the modified cluster back on my truck I found the plug taped to the wire harness for the tach, but not for the clock. I later plugged all of the items back in order to see if the tach worked. And my luck it did not work. Do I need to hard wire the clock to a hot power source and a ground or should there be a plug attached to my wire harness? After plugging in all of the plugs and starting the truck, the tach did not move at all. I do not understand why the tachometer did not work either. I checked and there was a good 10 amp fuse in section 8 of the fuse box. I even changed the fuse just in case the previous fuse was broken. So far I have not located the resistor for the tach, I may not have one. I will continue to look for it. Does anyone have info on where I should look and what does it look like. All help is greatly appreciated. I will trouble shoot why I am not getting heat this week-end. I will check my heater core lines and the thermostat. Thanks for all of your time and help. John. Quote Link to comment
datzenmike Posted January 5, 2012 Report Share Posted January 5, 2012 The '84 tach resistor plug is located (may be missing the 2.2K ohm resistor) on driver's side harness behind the headlights near the dual coils. It will be tapped up. The resistor can be found on any '80-'96-ish car or truck with a dash tach. The clock should have a 2 wire plug (marked A,B) on it that connects to the dash harness. There should be a 3 wire plug (marked C, D, E) on the dash harness that plugs into a hole just below the back of the tach on the gauge cluster. 1 Quote Link to comment
84 Nissan/Datsun Truck Posted January 6, 2012 Author Report Share Posted January 6, 2012 Thanks for all of your help. I found the plug for the clock and it is know working. :) I will search at my local salvage yard for a resistor for the tach asap . Thanks for all of the help. The Ratsun members are very knowledgeable and supportive. Thanks Again, John. Quote Link to comment
ZackeryNM Posted January 27, 2012 Report Share Posted January 27, 2012 Something kinda relevant; I would like to know what size bulbs are in the cluster and how many are in there for one w/o the tach and clock. Thanks! Quote Link to comment
datzenmike Posted January 27, 2012 Report Share Posted January 27, 2012 It's the little ones on the right for the '83 and up 720. Not sure about the earlier ones. Quote Link to comment
ZackeryNM Posted January 28, 2012 Report Share Posted January 28, 2012 (edited) It's the little ones on the right for the '83 and up 720. Not sure about the earlier ones. So what is that? a 194 or something? kinda wanting to put in some leds Screw it I'll just open the thing up. thanks guys. Edited January 28, 2012 by ZackeryNM Quote Link to comment
