VoidDragon Posted December 11, 2011 Report Share Posted December 11, 2011 I seem to remember seeing it some where, but I can't find the right search query to bring it up. On a 72 510 goon, which position of the turn signal handle should trigger the brights? On my 620, you push forward to bright light. I just got done rewiring the headlight system with relays. One for the power draw & the switching system. It works, I've tested the relays seperately, and when I make the connection through the brights switch it works... Just reversed of what I thought it would. The relay is currently set up : 1 the "prime" wire, 12v+ from the stock head light wiring. 2 goes to the black/red wire from the old head light relay 3 ground 4&5 the grounds wires from the head lights. Does the system ground back through the old relay ground wires into the switches? Those are currently un used. Would that cause a double positive reversing the bright light switch? Quote Link to comment
rpowell25 Posted December 11, 2011 Report Share Posted December 11, 2011 On my '72 sedan it is stalk back towards the wheel. Stalk forward is lo beam. Quote Link to comment
Laecaon Posted December 11, 2011 Report Share Posted December 11, 2011 On my '72 sedan it is stalk back towards the wheel. Stalk forward is lo beam. This Quote Link to comment
VoidDragon Posted December 11, 2011 Author Report Share Posted December 11, 2011 Hmm opposite my truck. But I guess I wired it up correctly, thanks guys. Quote Link to comment
