EricJB Posted November 27, 2011 Report Share Posted November 27, 2011 So my NAPA guy has struck out twice. Does anyone have a part# for these that he can crossover to? I read somewhere that they are the same as a roadster, but the OD is too big.( on the seal) I'm pretty loyal to my parts guys, so I dont want to mail order if I can get them the info they need. My old seals have no #s on them . So even an old # from an old seal will help. Thanks Quote Link to comment
datsun65 Posted November 27, 2011 Report Share Posted November 27, 2011 If you have a RL411 (411SSS should be a RL411), then you should have disc brakes upfront. Caliper rebuild kits are still available from Nissan. Just order the rebuild kit for either a SPL311 or SRL311. If you have a PL410 or PL411 with drum brakes upfront, then you will need a kit for the front wheel cylinders of a spl310 (4 of them). They are available: http://datsunroadste...ES/brake_15.htm Quote Link to comment
EricJB Posted November 28, 2011 Author Report Share Posted November 28, 2011 Yes it is a RL411 w/discs. I have the caliper rebuild kits already in the calipers w stainless pistons I made. What I need are the #s for the wheel bearing seals. Sorry, should have been more specific. Thanks for the response. Quote Link to comment
67411sss Posted November 28, 2011 Report Share Posted November 28, 2011 I thought the disc were the same as early 510? Quote Link to comment
EricJB Posted November 28, 2011 Author Report Share Posted November 28, 2011 Are the wheel seals the same? Quote Link to comment
EricJB Posted November 28, 2011 Author Report Share Posted November 28, 2011 OK it appears they are the same as early 510 and z car. SKF# 18864, National# 1188. Thanks for the clue. Quote Link to comment
JH Bahn Posted December 25, 2011 Report Share Posted December 25, 2011 RL411 front disc brakes are NOT the same as the SPL311 or SRL311 roadsters; they are the same as the 510 as 67411SSS stated above. I have some info on front wheel bearings but nothing on the seal. Quote Link to comment
