josh817 Posted October 24, 2011 Report Share Posted October 24, 2011 In need of a passenger side outside door handle. Should be held on by two nuts on the inside of the door and that's it I believe. When you look in there the little arm on the handle that pushes down on the nylon roller/latch mechanism broke on mine so you pull the handle but the latch doesn't open. Thanks guys. I'm in Keller, Texas 76248 Edit: Need this, a look from the outside and the inside: Link to comment
wayno Posted October 26, 2011 Report Share Posted October 26, 2011 I have what you need, seems like there would be someone closer though. I found my box of 521 door parts, lots of pass. side ones, they are used though. I'll check what the small box costs, remind me as i forget things easily, PM me if you don't hear from me by thursday. wayno Link to comment
Tom@LRD Posted November 10, 2011 Report Share Posted November 10, 2011 I also have several doors I can pull parts from if you are still looking Link to comment
