laniadude Posted October 13, 2011 Report Share Posted October 13, 2011 What's the correct setting for the brake master pushrod? I notice that when I put my master cylinder on, before it sits flush with the booster the pushed is already pushing the master cylinder. Is it supposed to do that? Quote Link to comment
hawaii_620 Posted October 14, 2011 Report Share Posted October 14, 2011 What's the correct setting for the brake master pushrod? I notice that when I put my master cylinder on, before it sits flush with the booster the pushed is already pushing the master cylinder. Is it supposed to do that? I'm not an expert, but I don't think it should be engaging the MC while the pedal is "neutral". Might want to wait to see what senior members on the forum have to say though, I could be wrong. Quote Link to comment
laniadude Posted October 14, 2011 Author Report Share Posted October 14, 2011 I did a little research..... you're right... it's not supposed to engage until the pedal is pressed.... Quote Link to comment
jdmdime Posted October 14, 2011 Report Share Posted October 14, 2011 you need to adjust your free play or your gonna have dragging brakes once they heat up.. Quote Link to comment
laniadude Posted October 14, 2011 Author Report Share Posted October 14, 2011 Yup will do thanks Quote Link to comment
datzenmike Posted October 14, 2011 Report Share Posted October 14, 2011 The spring inside the master is very stiff, I doubt the booster is strong enough to move it. Yes, be sure to check that you have about 2 or 3 mm (1/16") of peddle movement before there is any strong resistance. Quote Link to comment
