BURLEIGH Posted September 23, 2011 Report Share Posted September 23, 2011 Like the title says... I need to get my mechanical speedo working with the electronic sender on the S14 tranny. Any help is very appreciated! Thanks! Richard Quote Link to comment
MicroMachinery Posted September 23, 2011 Report Share Posted September 23, 2011 You should be able to just remove the electronic sensor from the trans and put an analog speedo cable in. Make sure it's the right sized gear, though, or your speedo will be off. Quote Link to comment
datzenmike Posted September 23, 2011 Report Share Posted September 23, 2011 Look for the speedometer pinions from '80 and up 720, 200sx and 2wd D-21 Hardbodys and WD-21 Pathfinders. The S13 240s and pretty much all others after '93 went to the same sensor you have. I have no idea on what number of teeth to look fo. Find something and see how far out you are and then look up or down in number of teeth. Quote Link to comment
BURLEIGH Posted September 23, 2011 Author Report Share Posted September 23, 2011 Thanks Guys! I was hoping it would be that easy... Quote Link to comment
datzenmike Posted September 23, 2011 Report Share Posted September 23, 2011 Actuallythere was a similar post. I just remembered that any pinion after '80 should work too, like in the 720 and 200sx Quote Link to comment
BURLEIGH Posted September 24, 2011 Author Report Share Posted September 24, 2011 So would the cog from the original transmission I pulled out of the 210 work??? Quote Link to comment
