VintageRice Posted September 21, 2011 Report Share Posted September 21, 2011 Looking for a good KA trans for my single slammer swap. Also looking for a flywheel, and header. Let me know what you got! Local preferred. (Wa) Thanks!! Link to comment
Guest kamakazi620 Posted September 23, 2011 Report Share Posted September 23, 2011 Looking for a good KA trans for my single slammer swap. Also looking for a flywheel, and header. Let me know what you got! Local preferred. (Wa) Thanks!! You can use a 720 Z24 trans it bolts up and their ALLways in the junkyard Link to comment
VintageRice Posted September 24, 2011 Author Report Share Posted September 24, 2011 Ok, cool. Good info thanks! Are they just as good? Link to comment
datzenmike Posted September 24, 2011 Report Share Posted September 24, 2011 No. The B type from a Z series will work but the C types are far stronger. B type C type Check out the width of the gears. The C are much wider and stronger. Larger shift fingers, better synchros. The 'C' has a thicker 1st/2nd shift rod and larger counter and mainshaft bearings in the case and adapter plate also. B type 56mm counter bearing (lower front) C type with 62mm counter bearing Note the larger bottom bearing is closer to the upper bearing. This is because it is larger. B and C cover plates below. Note that the C type has internal oil passages to better lubricate the lower counter bearing. The FS5W71B was used on the 280zx non turbo and that was about the upper limit for them, about 180hp? Seriously I don't know, but under 200hp probably. The FS5W71C was used on the non turbo 300zx and reliably handle 300hp. . Link to comment
VintageRice Posted September 24, 2011 Author Report Share Posted September 24, 2011 Wow, D-Mike Comes through again. ;) And with OICS! Love it. So the 720 pickup and the 280zx non-turbo both came with the "B" type correct????? And only the 300zx came with the "C" type? I guess either will be fine on my N/A Ka sohc. It'll be hopped up but 200hp would be a very high goal on it. Thanks again Mike. :thumbup: Link to comment
datzenmike Posted September 24, 2011 Report Share Posted September 24, 2011 So the 720 pickup and the 280zx non-turbo both came with the "B" type correct????? Yes, the '81 and up 720 and the '80-'83 200sx would also have the Z bolt pattern and would fit the KA . The '80s 280zx/Maxima were also 5 speeds but with L bolt pattern. The '84-'86.5 are CA bolt patterns. All FS5W71B And only the 300zx came with the "C" type? Hell no. The FS5W71C was used on the '86.5 and up Hardbody and Pathfinder, 200sx and later 240sx, '84 and up 300zx non turbo. The 300zx will have the VG30 motor and the 200sx were CA and VG motors. 2wd Hardbody and Pathfinder 4 cylinders will have the Z and KA motor bolt pattern you want. The 240sx were also KA motors, but the tranny is quite long and the shifter far back. They will fit and work in a 510 but the Hardbody 'C' type is a few inches shorter. Since you like oics... Both are FS5W71C type 5 speeds. The top one is from a D-21 Hardbody and the bottom is from an S13 240sx. You can see the relative length differences. I must say here that this is about fit only! There are several gear choices available between trucks and cars. The B type had some really wide ratio boxes for trucks and on the 200sx turbo cars. The C types had larger more powerful motors and so mostly mid and close ratio gear sets were used. :) Link to comment
VintageRice Posted September 25, 2011 Author Report Share Posted September 25, 2011 :o Now THATS how you answer a question!!! Thanks Mike, I suppose I'll owe you a ride in my carbed/Ka powered 510 at canby next year. :P :D Thats assuming I can decide on which 5speed to put in it!! LOL ;) Link to comment
