KingAnna Posted September 5, 2011 Report Share Posted September 5, 2011 updated! Well Its time to clear out parts that we have laying around and that wont be used. Here is the list. Feel free to make offers or trade for SR parts. Pics! http://s742.photobuc...datsun%20parts/ L20b motor-400 4 air box cleaner $50 each 5 cam sprocket $10 each 3 ac pump $50 each 1 power steering pump (jdm) $75 Datsun 510 A/C lines $30 2 L-20 valves cover 1 Datsun 1 Nissan $40 each inlet for air box (rubber tube) $15 510 shifter assembly for 4 speed $15 Datsun 510 antenna $10 2 L- Series Motor mount and brackets $10 4 round headlight bulbs high and low $25 for all 2 seat rail brackets $15 1 negative battery cable $5 1 gas door 510 $10 Misc. Datsun coolant hoses Make offer on ones you need, some new 2 l-series clutch fan $10 each 3 datsun 510 wiper motor $15 each 7 L-series thermostat housing $25 each 3 L-series mechanical fuel pumps $10 1 coil with ignitor $30 2 L-series oil pumps $15 L-series crank and water pulley $5 each 1 radiator cap $5 1 L-series water pump (feels and looks to be in good shape) $10 2 oil cap $5 each L-series distributor adaptor (metal peice below distributor) $10 L-series block off plates $5 each L-series points (make offer) L-series cap and rotors (new in boxes, we have a bunch) $15 1 L-series distributor $15 1 L-series flywheel need re surface $20 1 Datsun 510 never installed speedo cable $20 3 alternator $50 each 1 alternator bracket $10 3 L-series starters $30 each Datsun 510 trans cross member $25 4 misc. shifter $10 each 1 tensioner bracket $10 2 510 master cylinders $20 1 hazard switch SOLD 2 Datsun 510 quarter panel vents (none broken) $15 each 1 510 ignition switch with original key SOLD Washer fluid motor, make offer 1 wiper switch SOLD 1 cigarette lighter switch SOLD 1 510 driver mirror $10 1 L-series trans backing plate $15 1 510 drive shaft $50 1 510 complete hitch assembly $75 Lots of 510 exterior parts just ask 510 gas and brake pedals $30 for both 3 510 window regulators $15 each Rare 510 cluster no rpm, make offer Hvac controls and face plate $35 1 510 cluster cover, make offer 1 radio surround (no cracks) $25 510 interior door handles $5 each 8 510 headlight bezels $15 each 1 510 grill $25 1 510 gas tank $50 1 510 evap. Tank $30 1 L-series 4 speed trans $150 1 510 differential stock- make offer 1 510 open Subaru differential- 250 1 Link to comment
ariascarlos1990 Posted September 5, 2011 Report Share Posted September 5, 2011 What year is the grill from? Link to comment
KingAnna Posted September 6, 2011 Author Report Share Posted September 6, 2011 the grill is from a 72 Link to comment
KingAnna Posted September 6, 2011 Author Report Share Posted September 6, 2011 Link fail! :( Fixed. Link to comment
ariascarlos1990 Posted September 6, 2011 Report Share Posted September 6, 2011 the grill is from a 72 aww nevermind Link to comment
poopypants720 Posted September 10, 2011 Report Share Posted September 10, 2011 Any chance of sellingjust the top end off that motor? Head, intake/exhaust manifold, distributor, timing chain/cover, cam etc off that l20b? I know it already runs and all but I'm looking to possibly do a lz22 conversion when I rebuild my z22 motor... Link to comment
Radiant-Designer Posted September 10, 2011 Report Share Posted September 10, 2011 Interested in an Ac pump. I dont suppose the trans came from a 81-83 280zx... Do you know if the Ac pump is the same from a 620? Link to comment
pharouh Posted September 10, 2011 Report Share Posted September 10, 2011 What is the alternator bracket from, and can I see a pic? Link to comment
koolcarfam Posted September 11, 2011 Report Share Posted September 11, 2011 interested in the head light switch...it works ??? zip is 91977 Link to comment
SHRALP_GNAR Posted September 11, 2011 Report Share Posted September 11, 2011 is the drive shaft stock length or shortened for the tranny? Link to comment
72nismo Posted September 11, 2011 Report Share Posted September 11, 2011 Can I get picture of Distributor? Does it still work? Were u located at?? Link to comment
KingAnna Posted September 11, 2011 Author Report Share Posted September 11, 2011 I have 2 a/c pumps. Both look the same. I should have a pic with the part number if you want to check it. This is just extra stuff we have laying around and will never use. I would like to sell the motor as a whole. I do how ever have a ported head that has had a valve job, new springs, seals and a cam installed. It was never installed. I dont know the specs of it but it looks like there was decent work done. Alt bracket should have been from the original l16 from the 510. I believe i have a pic of it on photo bucket. If not i would gladly take a photo for you. Head light switch works. The shipping on it would be 7 bucks. Drive shaft is a stock length. Just a extra we had laying around. The one in the car now is shortened. I dont know if the dis works but i do have a pic of it on photo bucket at the link posted above in my first post. Link to comment
mosilva2782 Posted September 11, 2011 Report Share Posted September 11, 2011 intrested in the power steering pump pm me Link to comment
SHAMUS'WAGON Posted September 14, 2011 Report Share Posted September 14, 2011 I'm looking for rear drum adjuster for my 510 goon Link to comment
tneudy Posted September 16, 2011 Report Share Posted September 16, 2011 i"ll take the antenna. any windshield wipers and tail lights? Link to comment
KingAnna Posted September 17, 2011 Author Report Share Posted September 17, 2011 i"ll take the antenna. any windshield wipers and tail lights? Yes I have tail lights and windshield wipers I'll pm you with pictures. Link to comment
rallystokes Posted September 19, 2011 Report Share Posted September 19, 2011 I'm interested in 1 right and 1 left front caliper. Please pm me for shipping and payment info. Link to comment
koolcarfam Posted September 19, 2011 Report Share Posted September 19, 2011 I WILL TAKE THE HEADLIGHT SWITCH...THANKS..PAYPAL OR CASHIERS CHECK? Link to comment
KingAnna Posted September 19, 2011 Author Report Share Posted September 19, 2011 intrested in the power steering pump pm me pm sent. Link to comment
pondking Posted September 27, 2011 Report Share Posted September 27, 2011 is this still for sale? hazard switch $5 510ignition switch with original key $25 Link to comment
KingAnna Posted September 28, 2011 Author Report Share Posted September 28, 2011 is this still for sale? hazard switch $5 510ignition switch with original key $25 yes they are. PM sent Link to comment
TENDRIL Posted September 28, 2011 Report Share Posted September 28, 2011 how much shipped to 94553 CA Link to comment
paradoxx Posted September 28, 2011 Report Share Posted September 28, 2011 Is it gone the 510ignition switch with original key $25??? Link to comment
KingAnna Posted September 28, 2011 Author Report Share Posted September 28, 2011 how much shipped to 94553 CA already sold Link to comment
