Npdavies. Posted September 5, 2011 Report Share Posted September 5, 2011 So I just had a quick question about offset and such. So my Z has been lowered and we have about 3 inches from the tire to the fender, which is with 195/60/14. We are planning on putting 16x7 Rota RB's with 205/55/16. Which leads me to my question, if we were to put +40mm offset on the front, and +4mm offset in the back, would there be any rubbing issues or anything? We figured out that height won't be an issue, with 1.5 inches left after a 16 inch wheel is put on. So the only actual question is relating to offset. Any input would be appreciated! Thanks. Quote Link to comment
INDY510 Posted September 5, 2011 Report Share Posted September 5, 2011 . I don't know anything about Z cars,,,,,, but I KNOW a +40 offset will NOT fit in the front ,, , , you probably need a somwhere between +4 to +22mm 1 Quote Link to comment
Npdavies. Posted September 5, 2011 Author Report Share Posted September 5, 2011 Thanks very much. We ended up with just doing 16x8 with +10 all around. :P Quote Link to comment
