1968 wiper motor w/linkage
jefe de jefes
  • 3 months later...
  • Replies 4
If you just want to see if the motor works, remove the liinkage, connect the metal part to the negative terminal. Use a multi tester to see which of the other pins will form a closed circuit with the single pin and hook those to the positive. If the shaft spins fast its good. If it is slow try to lube the shaft. If it still wont go fast, its bad. If it wont move, thats kinda stating the obvious :-)
