Ron1200 Posted September 19, 2018 Author Report Share Posted September 19, 2018 I thought I had updated my original post as my opinion of 'Air Shocks' changed so dramatically. I hate when posts don't have a resolution... Originally reported by me Sept 2011: These shocks suck! Updated opinion Aug 2017: This thing drives/rides great with the air shocks and 720 4x4 springs. The problem was not the air shocks, but the mono-leaf springs. Changing nothing but the springs improved the ride is 110% (or more)... No more bouncy-bouncy, just a well controlled ride. It rides like a car now. Read about it here. 2 Quote Link to comment
gene knight Posted February 22, 2020 Report Share Posted February 22, 2020 (edited) Ron1200: what is the part# /name brand of air shocks you installed Edited February 22, 2020 by gene knight Quote Link to comment
Ron1200 Posted April 27, 2020 Author Report Share Posted April 27, 2020 Since I sold the 620, I've not logged in here much... So sorry for the late reply. I responded to another member on this topic, so posting up that response here. I think I used Monroe MA805 Max-Air Adjust Shock Absorbers..I got them off Amazon. I chose these because they were easy to get... If I remember correctly, they were in the $50 - $60 range at the time. Here the link: https://www.amazon.com/Monroe-MA805-Max-Air-Adjust-Absorber/dp/B000C55T4A/ I looked for a picture of the 620 with a motorcycle (Honda VTR1000 - about 430 lbs / 195 k) in the back, but couldn't find the photo. The loaded ride height was a little higher than below. I do remember it hitting the bump stops in the back a couple of times. I don't know how much air was in it, but it wasn't at max pressure, and I could/should have use more air. I most I carried was 20, 40 lb bags of garden soil. About 800 lbs total from town - only 6 miles. Yes, I typically ran 20-30 psi. I would add air just until the bed started to rise. I didn't want it to high. The four best things I did to the suspension in order: 1. Put on the 720 springs. 2. Put on the low profile bump stops (may not apply to you). 3. Put on the air shocks to add usability as a daily driver. 4. Use 70 series tires - the large tire sidewall really helps with ride quality. I hope this info is useful. 1 Quote Link to comment
