oldschool80sguy Posted August 26, 2011 Report Share Posted August 26, 2011 Could someone show me a pic or a document that shows the correct nuts and bolts needed to put the buckets back together? I have mine stripped and powder coated but have no idea what hardware to use or where to get the special grooved screws and plastics. Thanks for any help. Quote Link to comment
SR20-620 Posted August 26, 2011 Report Share Posted August 26, 2011 rock auto sometimes has the headlight adjusters with adjustment screws, dorman makes them. Also the retaining ring screws can be bought @ any hardware store, im not sure on thread pitch. Quote Link to comment
D52E Posted August 26, 2011 Report Share Posted August 26, 2011 You can try looking up the part numbers and see if they are available from nissan. This website has the part numbers published - www.carpartsmanual.com #13 Adjuster Bolt is available from Nissan still and its about $1.50(26022 58000 - SCREW-ADJUSTING) #12 (Spring) is No Longer Available #14 Screw is available and about $0.82 each Quote Link to comment
oldschool80sguy Posted August 26, 2011 Author Report Share Posted August 26, 2011 Thank you both! Quote Link to comment
oldschool80sguy Posted August 27, 2011 Author Report Share Posted August 27, 2011 You can try looking up the part numbers and see if they are available from nissan. This website has the part numbers published - www.carpartsmanual.com #13 Adjuster Bolt is available from Nissan still and its about $1.50(26022 58000 - SCREW-ADJUSTING) #12 (Spring) is No Longer Available #14 Screw is available and about $0.82 each when i first saw your reply on my phone it didn't show the image. Now that i see it this will be easy. thank you for finding it for me. Quote Link to comment
hang_510 Posted August 27, 2011 Report Share Posted August 27, 2011 the plastics may still be avail from nissan. try chico nissan for someone who will look hard for them. Quote Link to comment
