jnec510 Posted August 14, 2011 Report Share Posted August 14, 2011 I have a 69 510 wiring harness, but I'm tryin to use a 72 510 fuse box. Is there a diffrence? If so can I convert? Quote Link to comment
NICKLE&DIME Posted August 22, 2011 Report Share Posted August 22, 2011 Yes there is. A 72 has the headlight relay wire ( red with a yellow tracer) separate coming from the fuse block rather than it being incorporated into the plug (white larger plug of the two that connect to the fuse box) Trace and take note of the wire codes/colors. Quote Link to comment
jnec510 Posted August 23, 2011 Author Report Share Posted August 23, 2011 thank you im gonna go check that out right now. all i got working is heater an power to the coil. i need to gey her going quick. thanks again Quote Link to comment
DISLEXICDIME Posted August 24, 2011 Report Share Posted August 24, 2011 i posted diagram pics http://community.ratsun.net/topic/24801-kevins-70-510/page__st__160 Quote Link to comment
jnec510 Posted August 26, 2011 Author Report Share Posted August 26, 2011 h2theizzo hooked me up with a 69 fuse panel so should be rock and roll. thanks for the info Quote Link to comment
