pascualid Posted March 13, 2008 Report Share Posted March 13, 2008 Any thoughts on this carb for a 620 needing one? Thank you. Quote Link to comment
Guest DatsuNoob Posted March 14, 2008 Report Share Posted March 14, 2008 I got a weber 34/34, and although the linkage is slightly different, It works great! Why be like everyone else with a 32/36? Not that much different though. Both butterflies are the same size rather than one small and one larger, they open up one at a time just like a 32/36. Big improvement over the stock hitachi. I just bent the linkage bracket a little in the right direction and it worked out fine. Nothing wrong with a 34 34 in my book, had to barely grind the adapter plate holes for clearance on the butterflies, and that's it. Quote Link to comment
slayer Posted March 14, 2008 Report Share Posted March 14, 2008 does any one know if this is a good price. and if so is this all some one would need to change a 620 to this weber? http://portland.craigslist.org/clk/pts/605772601.html Quote Link to comment
banzai510(hainz) Posted March 14, 2008 Report Share Posted March 14, 2008 the carbs are pretty much intercahngable ,but youll still need the correct adapter to mount on the nissan intake manifold webercarbsdirect.com Quote Link to comment
datsunfish Posted March 15, 2008 Report Share Posted March 15, 2008 From what I have seen,for the most part all jap trucks came with the same carb bolt pattern.A Aisan carb from a Mazda b2000 will fit the Hitachi spacing for a Datsun.All adapters for a weber I have pulled fit a Datsun.From Mazda,courier,and even a s10 I think... I dont see a pic of the solex 34/34 but I think I know what it is.Dodge used Solex for alot of their carbed rigs.One might be a 2 barrel jetted for a 318 and another for a 4 banger. I met a guy recently who is a carb specialist and he told me that instead of a weber or Holley knockoff I could use a Rochester 2gc carb.It is a 2 barrel in the area of a dges.He said they work great and are easy to adapt.He said to do some research first as those also come on v8s so I think they would need to be re jetted. Quote Link to comment
