FiveTenzo Posted August 6, 2011 Report Share Posted August 6, 2011 Hey a have a few KA24 swap questions, sorry for the noob question but tried searching but didnt find much. First, im guna be running a Walboro 255 inline/external and just wanted to know where is the best place to place it for the best performance? Second, ive read for the ka24 swap that and you have to do is weld the tip from the 240sx and weld it onto the 510 pedal. but what about the part that stop the pedal? (pictured below) I have the one from the 240sx but when i put it on it seem to not let the pedal go very high. is there another peice i shuld use or a bracket from another car? And third, i have new 510 engine mounts, i didnt want the 620 mounts cust i wanted my engine to sit lower, but do i have to run spacer for them to work and if i do where and how many(am guessing i can use washers). Thanks in advance Quote Link to comment
AuosGnaf Posted August 10, 2011 Report Share Posted August 10, 2011 Hey a have a few KA24 swap questions, sorry for the noob question but tried searching but didnt find much. First, im guna be running a Walboro 255 inline/external and just wanted to know where is the best place to place it for the best performance? Second, ive read for the ka24 swap that and you have to do is weld the tip from the 240sx and weld it onto the 510 pedal. but what about the part that stop the pedal? (pictured below) I have the one from the 240sx but when i put it on it seem to not let the pedal go very high. is there another peice i shuld use or a bracket from another car? And third, i have new 510 engine mounts, i didnt want the 620 mounts cust i wanted my engine to sit lower, but do i have to run spacer for them to work and if i do where and how many(am guessing i can use washers). Thanks in advance 1. Fuel pump (inline/external) : As long it's mounted lower than the fuel tank in the trunk somewhere then you'll be fine. That's what I've seen and read. I have a wagon myself and mine is mounted under the chassis because of the location of my fuel tank. 2. Pedal: Grind and welded 240sx tip onto my stock pedal and it works just fine. Remove the piece that is preventing your stock pedal from going back into position. All you need is the black plastic piece that you can bolt/screw into the outside of the fire wall/engine bay. * There's a "How to" thread with pictures. * 3. Motor mounts: You can use the 510's stock mounts without spacers for your KA, but this may come down to personal preference and/or budget. I'm using the stock mounts. There may be slight bends here and there with the rubbers, but for the most part you should be OK. 4. Take your time. Don't rush your swap. Feel free to add and/or assist our bro. Thanks! 1 Quote Link to comment
tredspeed Posted August 10, 2011 Report Share Posted August 10, 2011 i sell a cross member setup fro s13 mounts no spacers and stock brackets thats my preference if you are going to run an external do yourself a favor and ru a surge tank pedal is easy as stated above but cut off the stop and use your stock 510 one its adjustable good luck Quote Link to comment
FiveTenzo Posted August 13, 2011 Author Report Share Posted August 13, 2011 Thanks AuosGnaf Quote Link to comment
FiveTenzo Posted September 18, 2011 Author Report Share Posted September 18, 2011 What About hitting the tranny tunnel? i want to try to hit it in the most i can so when i out the the engine and tranny in there wont be any problems. So which bolts on the KA tranny hit the tranny tunnel?? Quote Link to comment
Guest kamakazi620 Posted September 18, 2011 Report Share Posted September 18, 2011 Heres a cable thread http://community.ratsun.net/topic/29608-how-to-ka-throttle-cable-in-a-510/page__p__441300__hl__%2Bka+%2Bthrottle+%2Bcable__fromsearch__1#entry441300 Quote Link to comment
FiveTenzo Posted September 18, 2011 Author Report Share Posted September 18, 2011 Yeah i found it after he told me about it. thank tho:thumbup: Quote Link to comment
