littlemotorman Posted July 31, 2011 Report Share Posted July 31, 2011 Hi I was wondering if anyone could post picture for me of non modified Datsun 620 frame?Need to see parking brake setup were the cable brakets are and such.My frame has no cross member were everthing bolts to. I am making new cross member so need to see were barket sits and bake further on frame were cables casing ends go.Picture is really all I need.Thanks Quote Link to comment
Z chopper Posted July 31, 2011 Report Share Posted July 31, 2011 hey motorman where about in Canada are you? I am sure someone will be popping in to help with a photo or diagram Quote Link to comment
littlemotorman Posted July 31, 2011 Author Report Share Posted July 31, 2011 Hi Z chopper I live in Dobbinton,Ontario. Quote Link to comment
grant Posted July 31, 2011 Report Share Posted July 31, 2011 nice to see any other person in ontario! we should all do a meet sometime!! I'm away from my shop for the long weekend, if no one else posts up a pic I'll throw mine up on the hoist and post up a pic when I get back Quote Link to comment
Radiant-Designer Posted July 31, 2011 Report Share Posted July 31, 2011 not sure if this will help..... I live in NH and thats where the truck is, but am currently in TX on business I can take any other pics you need when I get home, I was going to POR the frame so the bed is still off https://docs.google....VmMTg5&hl=en_US Quote Link to comment
littlemotorman Posted August 2, 2011 Author Report Share Posted August 2, 2011 Thanks for the replys everyone,still no picture of frame.The link from Radian -Designer didn't work .I tried to search it but had no luck,the only frame pick I seem to be able to find are modded frames.Its almost like it clasiffied information.I guess I will have to hoke it if I can't find picture today,I want to sand blast it tommorrow. Quote Link to comment
pharouh Posted August 2, 2011 Report Share Posted August 2, 2011 Is this what you need? The arrow points to the front of the truck and the red line is the crossmember. Quote Link to comment
littlemotorman Posted August 2, 2011 Author Report Share Posted August 2, 2011 Thanks pharouh that great it's exactly what I need .I also need to see the brackets further back on the frame there is one on both sides.It is were cable comes out of wheel and goes into holding bracket.Just need to see about were they are on the frame. Quote Link to comment
pharouh Posted August 3, 2011 Report Share Posted August 3, 2011 I know the ones you're talking about. I believe they mount on the inside frame rail above the front spring perch on the rear springs.Here's some better pics. This is in front of the spring perch. #1 is the bolt for the spring and #2 is the ebrake cable. Quote Link to comment
littlemotorman Posted August 10, 2011 Author Report Share Posted August 10, 2011 Thanks pharouh those pictures helped alot.Now my 521 will have 620 parking brakes.I will post somre pics of my build when I get some time. Quote Link to comment
