El Caballo Loco Posted July 6, 2011 Report Share Posted July 6, 2011 I'll get some pics up in the next 4-5 days. I WILL NOT SEPERATE the parts from the car. 1971 Datsun 240Z, Series II Location: Colorado Springs, CO 80910 Miles: 27,354 I would estimate that the odometer has rolled once, but not twice VIN: HLS30-37577 Engine: L24 MSA Header, Ceramic coated, custom 2.5" exhaust (does not sound ricy at all) Older style SU Carbs (rebuilt in 2010, three screw bell-tops) N36 Intake with water warmer passages blocked off Gear reduction starter 280Z 60 Amp alternator 280Z Distribuotr w/ E12-80 Module MSD Blaster SS Coil The pre-formed metal fuel lines have been replaced with 1/4" ID rubber fuel line in the engine compartment New Duralast battery Transmission: Later model 280Z 5-speed transmission Interior: 1993 Prelude Seats Black interior (I believe it's dyed but they did a good job. There is a bit of blue showing through in places) Sony Xplod CDX-GT10W Cd player Sony Xplod SpeakerS New front mats and rear deck carpet with Z logo New rear hatch seal Stock steering wheel Stock 4-speed shifter Misc: Dual piston front brake upgrade (Supra front brake upgrade) New rear strut cartridges The bad (DUN DUN DUN!): The car has some rust problems starting to show through the paint as well as a hole in the left front fender, yet the frame rails are in excellent condition The paint is dirty, to say the least Trim has been removed on the drivers side. I was experimenting with looks The car was keyed in December, 2009. One scratch all the way around. Plastic cover for manual choke is broken Hood was dented in the front somehow There is one 4"-6" crack in the passenger side of the dash The CD player shuts off when shifted into 1st, 3rd, or 5th gear (fuse box wiring?) There are places where there are oddball screws or washers, or something has been zip-tied instead of properly secured as it should be Has a slight vibration in the front end that I can't find The factory clock doesn't work The fuel gauge needle just stopped working in the past month. It takes a tap or two to read correctly Extra parts, most used: Original Spare Original Jack Original Tool bag P90 Head (virgin) N47 Head (virgin) N42 Head (virgin) N42 Block (virgin) N42 Crank (woodruff key slot needs welded back up and re-machined) P90 Valvetrain N47 Valvetrain N42 Valvetrain N42 Connecting Rods N42 Pistons 240SX Throttle Body 280Z FI Intake Manifold Factory 240Z Exhaust Manifold Factory 240Z Intake Housing cover E-48 Intake Manifold Timing Cover Two dissassembled SU Carbs (4 screw bell-tops) Rear View Mirror NIB Driver & Passenger door seals Two spare tires, 60% tread Three Valve Covers (two n/a, one turbo) Extra Oil Pump NIB 280Z Throw Out bearing Two Starters (one factory, one gear reduction) Extra factory alternator Stock 240Z front calipers Misc. Bulbs Extra Header New Valve Cover Gasket Oil Pan Misc. Small Parts (dizzy drive gear, oil pan rails, dipsticks, etc.) Cowl Panel Rear Hatch Strut $2,000 BUYER PAYS SHIPPING AND TAX, TITLE, AND LICENSE 1 Link to comment
Dirk Diggler Posted July 6, 2011 Report Share Posted July 6, 2011 Never heard of a series 2 Z. Link to comment
El Caballo Loco Posted July 7, 2011 Author Report Share Posted July 7, 2011 Never heard of a series 2 Z. I believe the Series I Z was '70-mid '71 and the later model 240Zs were considered Series II. The more desirable and rarer of the two is obviously the Series I. Link to comment
Dirk Diggler Posted July 7, 2011 Report Share Posted July 7, 2011 I believe the Series I Z was '70-mid '71 and the later model 240Zs were considered Series II. The more desirable and rarer of the two is obviously the Series I. Good thing I have a series one ;). I wasnt aware that they had different series, im assuming they made slight adjustments and those became the series 2? Get some pictures up! :P Link to comment
Skib Posted July 7, 2011 Report Share Posted July 7, 2011 70-71 are referred to as series one, but theres really not a ton of difference aside from carbs (72 started getting smog stuff and the 73 got the full blown smag flat tops) and minor things Link to comment
AZhitman Posted July 8, 2011 Report Share Posted July 8, 2011 S-1 were built from 10/69 to 12/70. Easiest way to ID them is the vents on the rear hatch. Also the S-1 had "240Z" on the c-pillar, whereas S-2 has the round Z medallion. S-1 steering wheel had indentations, not holes, on the spokes. Link to comment
El Caballo Loco Posted July 10, 2011 Author Report Share Posted July 10, 2011 I've never had that accurate of a description of the differences between the two Series cars. Thanks guys. There was some stuff I wanted to do before I got pics but the weather has been keeping me from them. I understand this thread it worthless without pics. I have older pictures of the car from the previous owner but I would rather not mis-represent the vehicle since the paint has deteriorated since then and some things have been removed. If you want to bust my balls about not having many/any posts, go for it. I get on this forum to gather information and do research. Would you rather I shoot out a bunch of mindless posts that have no point what so ever? Just to clear some things up: The car is VERY drivable and fires right up with no issues. The exterior is white. Link to comment
Skib Posted July 11, 2011 Report Share Posted July 11, 2011 If you want to bust my balls about not having many/any posts, go for it. I get on this forum to gather information and do research. no ball busting here. proceed :lol: Link to comment
Dirk Diggler Posted July 11, 2011 Report Share Posted July 11, 2011 You only get your balls busted if you don't post pictures Link to comment
El Caballo Loco Posted July 16, 2011 Author Report Share Posted July 16, 2011 Forgot to add: - New radiator in ~2008 - I have all the emblems stored away Link to comment
El Caballo Loco Posted July 20, 2011 Author Report Share Posted July 20, 2011 $4,500 OBO Link to comment
El Caballo Loco Posted July 21, 2011 Author Report Share Posted July 21, 2011 $3,500 I need it gone! Link to comment
Skib Posted July 21, 2011 Report Share Posted July 21, 2011 wish I had the cash, this is a good project. Link to comment
El Caballo Loco Posted July 21, 2011 Author Report Share Posted July 21, 2011 That's as low as it's going to go too. That's breaking even. Did you ever get my pm? Link to comment
El Caballo Loco Posted July 26, 2011 Author Report Share Posted July 26, 2011 Still $3,500! Photos can be found here - http://s253.photobucket.com/albums/hh54/elcaballoloco1/Datsun/ Link to comment
El Caballo Loco Posted July 28, 2011 Author Report Share Posted July 28, 2011 Shameless bump. Link to comment
El Caballo Loco Posted July 30, 2011 Author Report Share Posted July 30, 2011 Money talks. I may go lower than $3,500 for the right offer! Link to comment
El Caballo Loco Posted August 4, 2011 Author Report Share Posted August 4, 2011 $3,250.00 Link to comment
El Caballo Loco Posted August 8, 2011 Author Report Share Posted August 8, 2011 $2,900.00 and that's where it's staying. That's what I paid for the car before tax, title, and license. Losing some on parts here but oh well. At least I'll break even on the main cost. If not, I'll just sit on it. Link to comment
Dirk Diggler Posted August 9, 2011 Report Share Posted August 9, 2011 :blink: why hasnt anyone snagged this yet? pics arent working... Link to comment
El Caballo Loco Posted August 9, 2011 Author Report Share Posted August 9, 2011 Not even on the link in post 19? Ugh. I'm horrid at this photo thing. Link to comment
