1971 240Z, Series II, Strong driver $3,500.00
I'll get some pics up in the next 4-5 days. I WILL NOT SEPERATE the parts from the car.
1971 Datsun 240Z, Series II
Miles: 27,354 I would estimate that the odometer has rolled once, but not twice
VIN: HLS30-37577
Engine:
L24
MSA Header, Ceramic coated, custom 2.5" exhaust (does not sound ricy at all)
Older style SU Carbs (rebuilt in 2010, three screw bell-tops)
N36 Intake with water warmer passages blocked off
Gear reduction starter
280Z 60 Amp alternator
280Z Distribuotr w/ E12-80 Module
MSD Blaster SS Coil
The pre-formed metal fuel lines have been replaced with 1/4" ID rubber fuel line in the engine compartment
New Duralast battery
Transmission:
Later model 280Z 5-speed transmission
Interior:
1993 Prelude Seats
Black interior (I believe it's dyed but they did a good job. There is a bit of blue showing through in places)
Sony Xplod CDX-GT10W Cd player
Sony Xplod SpeakerS
New front mats and rear deck carpet with Z logo
New rear hatch seal
Stock steering wheel
Stock 4-speed shifter
Misc:
Dual piston front brake upgrade (Supra front brake upgrade)
New rear strut cartridges
The bad (DUN DUN DUN!):
The car has some rust problems starting to show through the paint as well as a hole in the left front fender, yet the frame rails are in excellent condition
The paint is dirty, to say the least
Trim has been removed on the drivers side. I was experimenting with looks
The car was keyed in December, 2009. One scratch all the way around.
Plastic cover for manual choke is broken
Hood was dented in the front somehow
There is one 4"-6" crack in the passenger side of the dash
The CD player shuts off when shifted into 1st, 3rd, or 5th gear (fuse box wiring?)
There are places where there are oddball screws or washers, or something has been zip-tied instead of properly secured as it should be
Has a slight vibration in the front end that I can't find
The factory clock doesn't work
The fuel gauge needle just stopped working in the past month. It takes a tap or two to read correctly
Extra parts, most used:
Original Spare
Original Jack
Original Tool bag
P90 Head (virgin)
N47 Head (virgin)
N42 Head (virgin)
N42 Block (virgin)
N42 Crank (woodruff key slot needs welded back up and re-machined)
P90 Valvetrain
N47 Valvetrain
N42 Valvetrain
N42 Connecting Rods
N42 Pistons
240SX Throttle Body
280Z FI Intake Manifold
Factory 240Z Exhaust Manifold
Factory 240Z Intake Housing cover
E-48 Intake Manifold
Timing Cover
Two dissassembled SU Carbs (4 screw bell-tops)
Rear View Mirror
NIB Driver & Passenger door seals
Two spare tires, 60% tread
Three Valve Covers (two n/a, one turbo)
Extra Oil Pump
NIB 280Z Throw Out bearing
Two Starters (one factory, one gear reduction)
Extra factory alternator
Stock 240Z front calipers
Misc. Bulbs
Extra Header
New Valve Cover Gasket
Oil Pan
Misc. Small Parts (dizzy drive gear, oil pan rails, dipsticks, etc.)
Cowl Panel
Rear Hatch Strut
$2,000
BUYER PAYS SHIPPING AND TAX, TITLE, AND LICENSE
  • Replies 32
I believe the Series I Z was '70-mid '71 and the later model 240Zs were considered Series II. The more desirable and rarer of the two is obviously the Series I.
Good thing I have a series one ;). I wasnt aware that they had different series, im assuming they made slight adjustments and those became the series 2? Get some pictures up! :P
S-1 were built from 10/69 to 12/70. Easiest way to ID them is the vents on the rear hatch. Also the S-1 had "240Z" on the c-pillar, whereas S-2 has the round Z medallion. S-1 steering wheel had indentations, not holes, on the spokes.
I've never had that accurate of a description of the differences between the two Series cars. Thanks guys.
There was some stuff I wanted to do before I got pics but the weather has been keeping me from them. I understand this thread it worthless without pics. I have older pictures of the car from the previous owner but I would rather not mis-represent the vehicle since the paint has deteriorated since then and some things have been removed.
If you want to bust my balls about not having many/any posts, go for it. I get on this forum to gather information and do research. Would you rather I shoot out a bunch of mindless posts that have no point what so ever?
Just to clear some things up:
The car is VERY drivable and fires right up with no issues.
The exterior is white.
