Topher88 Posted June 25, 2011 Report Share Posted June 25, 2011 Im going to go look at a 240sx with the motor still in it so i can swap that into my 510. Im going to do a compression test on it so is there anything else i should look for? what kind of compression should i be looking for? ill check the oil and coolent to make sure there is no oil or water in them. the car has been sitting for a year so im not really dont want to try starting it up. it comes with a 5 speed so i know to try that out and make sure that it feels good when you shift. anything else? Quote Link to comment
Guest kamakazi620 Posted June 25, 2011 Report Share Posted June 25, 2011 Im going to go look at a 240sx with the motor still in it so i can swap that into my 510. Im going to do a compression test on it so is there anything else i should look for? what kind of compression should i be looking for? ill check the oil and coolent to make sure there is no oil or water in them. the car has been sitting for a year so im not really dont want to try starting it up. it comes with a 5 speed so i know to try that out and make sure that it feels good when you shift. anything else? I thinks you gots it covered YO! Quote Link to comment
510kevin Posted June 25, 2011 Report Share Posted June 25, 2011 Im going to go look at a 240sx with the motor still in it so i can swap that into my 510. Im going to do a compression test on it so is there anything else i should look for? what kind of compression should i be looking for? ill check the oil and coolent to make sure there is no oil or water in them. the car has been sitting for a year so im not really dont want to try starting it up. it comes with a 5 speed so i know to try that out and make sure that it feels good when you shift. anything else? why wouldnt you want to start it? seems like it would give you a lot more feedback if you could see and hear it run.... Quote Link to comment
datsunrides Posted June 25, 2011 Report Share Posted June 25, 2011 If the compression is good, pull the valve cover and look to see if the timing chain guides are good. The higher mileage ones I have seen usually have a broken guide sitting in the oil pan. Mark Quote Link to comment
Guest kamakazi620 Posted June 25, 2011 Report Share Posted June 25, 2011 why wouldnt you want to start it? seems like it would give you a lot more feedback if you could see and hear it run.... Idea put marvel mystery oil in them cylinders before id start it Quote Link to comment
510kevin Posted June 25, 2011 Report Share Posted June 25, 2011 Idea put marvel mystery oil in them cylinders before id start it roger that big trucker!!! :lol: Quote Link to comment
Guest kamakazi620 Posted June 25, 2011 Report Share Posted June 25, 2011 If the compression is good, pull the valve cover and look to see if the timing chain guides are good. The higher mileage ones I have seen usually have a broken guide sitting in the oil pan. Mark True dat yeah definetly take off them valve cover and investigate, I forgot I did that when buying my ka Quote Link to comment
Topher88 Posted June 25, 2011 Author Report Share Posted June 25, 2011 thanks guys. ya after i do a compression test ill see how the oil looks and hopefully the gas is good and fire her up for a little. should i let it heat up then take it for a spin? Quote Link to comment
Guest kamakazi620 Posted June 25, 2011 Report Share Posted June 25, 2011 thanks guys. ya after i do a compression test ill see how the oil looks and hopefully the gas is good and fire her up for a little. should i let it heat up then take it for a spin? Pull the valve cover before you start to make sure them timming guides are good Quote Link to comment
