wtf carb shit??
Siqx20
Home made venturi kit?? Pulled these out if my carb. They look home made. My question is why??
Also I am pretty sure im jetted wrong. I feel like im leaning out. Any tips on jet sizes. Stock l20
Primary air: 170
Primary main: 120
Primary idol: 65
Prmary e tube: f50
Secondary air: 160
Secondary main: 120
Secondary idol: 50
Secondary e tube: f50
Pump jet: 50
  • Replies 8
Looks like air horns, not homemade but the mounting is dodgey. They are good for a couple % HP
They were down inside my venturi. Pretty sure they were being used to restrict the amount of air flow. a janky way of compensating for my to small of jetting.
Noone has any other opinions on jetting??? Should i be running both my mains at the same size? Oh DGV gurus help me!!! lol
The main jets should not be the same size.
Primary air: 170
Primary main: 120
Primary idol: 65
Prmary e tube: f50
Secondary air: 160
Secondary main: 120
Secondary idol: 50
Pump jet: 50
Here is Weber's recommendation for a stock L20B:
Main Venturi: 26/27
Aux Venturi: 3.5/3.5
Main Jet: 140/135
Em Tube: F50/F6
Air Corr Jet: 165/160
Idle Jet: 55/50
Pump Jet: 50
Needle Valve: 2.00
Yes, they list the mains to be 140/135, but i have taken apart several and most of them had 140/140 mains.
I might even have a couple 140's if you want to try them before buying, if you get up near portland(I5) area.Nnot really worth throwing money at shipping when you could spend that money on the jet.
