fryenretards Posted June 17, 2011 Report Share Posted June 17, 2011 i just got my newest 521 and it turns out if i turn my high beams on and off a couple times all of my running lights turn off including the dash first thought is the headlight switch havent tore into anything yet though any ideas? Quote Link to comment
banzai510(hainz) Posted June 17, 2011 Report Share Posted June 17, 2011 try a new fuse for that circut. could be cracked ends inside. usually when the dash light out the running light out in back Quote Link to comment
fryenretards Posted June 18, 2011 Author Report Share Posted June 18, 2011 Ya all the running lights go out, dash tail lights license plate front all of them, when it happens. im at work now so I can't check fuses. I just got it in the garage before work then had to leave, but wouldn't the lights go on and off when I hit a bump or something if the fuse was making temporary contact? it only does it when I switch from low beams to high beams a couple times in a row. Quote Link to comment
banzai510(hainz) Posted June 18, 2011 Report Share Posted June 18, 2011 find the high bean relay and pull connector off/on a few times and maybe it will clean the contacks by doing this. still replace the fuse esp if old(preventaive maint) Quote Link to comment
fryenretards Posted June 18, 2011 Author Report Share Posted June 18, 2011 ok ill see what i can find out sometime this weekend i plan on working on it thnx Quote Link to comment
