WTB: 280zx speedometer gear/assembly
Hello! It seems that I have a speedometer from a truck 5-speed, and it does not engage into the gear unless its turned 180 degrees, then it does not bolt in.
From the info I've gathered searching I need a 280zx speedometer. Either that, or if someone could provide the nissan part number that would be great! cool.gif
The only items I've found online are JUST the pinion gear. I need the actual ZX speedo gear housing, and there are no 280zx's in the junk yards around here anymore!
Its going in a 510 wagon... so 3.90 rear end. But I can figure out what gear I need after I get the housing.
I don't have any buyer or seller feedback on this forum, or any forum. I have met some members locally at events (69fjwagon and zhiguli510) so they can at least vouch that I am a real person.
  • Replies 3
It all depends on what trans you're running. (before 1980 or after?)
For a KA trans, you can also use ones from 2wd 720 pickups. (I used one from an '81). ('80 and newer I think work)
You can also just cut a slot in the other side and mount it that way also.
There are some realty good threads on it on here too.
Hmm So I could just sawzall and file down an edge on the other side.. I considered doing that but figured it would be better to have the right part. For a temp solution I could do that.
I'm pretty sure its a ZX pre-1980 5spd FS5W71B
Angle grinder with cut off disc. Just nick it like the other side. I've compared the worm gear on the main shaft and they look t same other than one was plastic. I don't know why they changed this in or around '80.
