Caliper hoses...
jchristians
Doing the 720 hub/caliper/hoses brake upgrade on my '71 521. I am using 1984 720 parts. Does the 1984 caliper have an inner and outer hose?? or just one hose going to caliper w/ banjo bolt? appreciate any help! these auto stores are not much help!! argh.
  • Replies 2
Inner and outer hose???
4x4 and 2x4 have different hoses. But the regular 2WD 1984 720 front brakes use one hose per side. I think the earlier ones used two steel tubes per side (steel tube to caliper) with a hose in between, but the 1984 uses one steel tube and one brake hose.
