erichwaslike Posted June 5, 2011 Report Share Posted June 5, 2011 ok so i went thru and deleted the starter solinoid from my harness as i am not going to have the automatic in the car. manual cars dont have the seconday solinoid. i removed the few wires i saw associated with it and re wrapped the harness. i now cant seem to locate the reverse switch wiring. also the schematic i have says 411 but it is obviously for a 410/411 b4 the tail light change and there is a relay on the fender that is associated with reverse lights cause i have used a multi meter to test continuity between it and the rear harnes plug and it is not on the shcematic. so any one that knows 411 wiring please chime in. its for a 67.5 411 sss.i really just need the revers light circut. thanks p.s. im sitting in my shop wires strewn around me, if anyone can walk me thru where it is supposed to go feel free to txt or call too. really need this done. 714 501 1seven08 Quote Link to comment
erichwaslike Posted June 5, 2011 Author Report Share Posted June 5, 2011 ok just got off the fone with gcmustang and i think he helped me figure it all out. seems to be a auto only relay so ill be removing it. thanks so much greg Quote Link to comment
ggzilla Posted June 5, 2011 Report Share Posted June 5, 2011 There is 'inhibitor' wiring for the starter in the ato harness. Youll want to remove it and splice the wires. Quote Link to comment
