dimedriver Posted July 12, 2011 Author Report Share Posted July 12, 2011 I got under the truck to loosen up the ebrake a little. And found a strange looking thing on the passanger side cable taking up slack. I loosened that up so it was no longer taking up any slack. The new drum fit a little better but still too tight. The old drum dropped right on. Minimal drag. I'm going to get the new one turned. I drove it around the block. Pedal is still a little spongy. Still needs a double pump to lock up the wheels. I need to bleed it again anyway. Its way better than before. Now its time to tune the bias valve. Quote Link to comment
yello620 Posted July 13, 2011 Report Share Posted July 13, 2011 So, are we making progress then by getting the rear working correctly first? Sounds like it. Your pedal is never going to be perfect with those huge front calipers, but you should be able to get it acceptable. Without rear lockup. Quote Link to comment
dimedriver Posted July 14, 2011 Author Report Share Posted July 14, 2011 Yeah, drove the truck around the block two days ago and remembered I didn't put new cotter pins in the crown nuts for the steering. Today I bleed the whole system again with the valve turned to full presser in the back. Then turned it all the to min for back. Then messed with the idle and topped up the oil. Then I drove the truck to the gas station and the pedal feel is not great but it's working if it was just a little stiffer it would be awesome for a truck. But its just about as soggy as any GM full size I have ever driven. No great not so bad im scared. I don't need to double pump:). This is the 1st time the truck has been out of the garage for more than a test in the driveway in a year. Im going to go to a gravel road and fine tune the brake proportioning valve soon. Next up fix up the steering maybe add power steering while still planing for bigger axles. Oh and maybe put some new piston rings and seals in the engine. It burns and leaks oil pretty good. -Dime Quote Link to comment
dimedriver Posted July 18, 2011 Author Report Share Posted July 18, 2011 Trailered truck to Hollister on Sunday. Forgot to try and do a panic stop while someone was watching. here are a few pics. It felt pretty good descending some hills. The rotors now have much less cross hatching on them. I guess its working pretty good but I would still like to fully test it. -Dime Quote Link to comment
dimedriver Posted July 22, 2011 Author Report Share Posted July 22, 2011 Hybrid Z had a review of the Wilwood unit. Looks like it can fit with some grinding. http://forums.hybridz.org/index.php/topic/99845-review-of-wilwood-1-bore-brake-master-cylinder/page__p__940121__hl__s12w__fromsearch__1#entry940121 So far I have not seen any issues. I will get some more testing in maybe next week or so. -Dime Quote Link to comment
yello620 Posted July 22, 2011 Report Share Posted July 22, 2011 Thats actually an interesting read if you follow the second link. Looks like that 1" master might be a decent option IF we could get a large enough booster in the trucks. Quote Link to comment
