banzai510(hainz) Posted June 2, 2011 Report Share Posted June 2, 2011 I think these are the best shock out there if still avail I think work better for the coil over set up esp if you have the higher rate springs so you can controll them. these are 280zx lenght but will work with the later 3 sizes of 510 struts if you put spacers at the bottom of the strut so the gland nut holds the cartridge down while using most of the threads in the strut. If to soft just adjust. I did mine at about 45deg. meaning out of 360deg I did just about 20 to 45 deg from the softest setting. http://classicgarage.com/280zx1.html Quote Link to comment
