az240z Posted May 29, 2011 Report Share Posted May 29, 2011 I just bought a 1978 510 which is the hL510 series. I am wondering if there is a place that has a microfiche or parts list with factory part#? Carparts has the early 69 to 73. Xenon doesn't have it. An interchange sight would be great . For example the seat belts are shredded, there must be other mfgs that used the same belt. I bought a Hollander interchange but it only shows interchange for that model. Any help is appreciated Quote Link to comment
datzenmike Posted May 29, 2011 Report Share Posted May 29, 2011 Up to June '78, 4 door in black: RH....... 86830 W5210 LH....... 86880 W5210 Hatchback/Hardtop/goon and 2 door are likely different numbers and the colors (brown/black/green) will cause a different number too. Give my your build date on the door tag and if 2/4 door etc and color. Quote Link to comment
az240z Posted May 29, 2011 Author Report Share Posted May 29, 2011 Up to June '78, 4 door in black: RH....... 86830 W5210 LH....... 86880 W5210 Hatchback/Hardtop/goon and 2 door are likely different numbers and the colors (brown/black/green) will cause a different number too. Give my your build date on the door tag and if 2/4 door etc and color. Build date is 4/78 and its a 4 door. Thanks for the part#. so is there a microfiche or parts list available? Quote Link to comment
