V8 620
the510
  • Replies 9
you're all fucked up! :fu:
he just wanted to know how to put it in the bed, so he could take it to the recycler.
you probably need a 12 pack and 2 strong friends.
lift it, roll in...
then you can drop the clutch, and the block at the same time when its time to unload
ditch the chev and go a small block ford!
lift it, roll in...
That's the only reason a V8 should be in a 620. If your going to V8 a mini truck at least do it to an s10 or something.
haha thanks for the replies. I actually was just curious if it would fit. But it sounds like hell. Maybe ill try a newer fuel injected nissan I4
Now theres something reasonable. SR fits in there decently, theres someone on here whos doing it. A few people actually. THe KA is also reasonable too, theres a few doing that one also. Look around, you should see a few threads on it.
