ggzilla Posted May 26, 2011 Report Share Posted May 26, 2011 Hard to find. You might consider a Datsun 620 tach, look almost identical and in fact were used in the newer Japan 1200s. It's what I'm using and it is a total bolt in. Just run a wire to the coil negative post and use the stock dash lamp wiring same as 1200 tach. Link to comment
yello620 Posted May 26, 2011 Report Share Posted May 26, 2011 What is a 1200 tach worth? Curious, i have one that i have not tested yet. Link to comment
ggzilla Posted May 26, 2011 Report Share Posted May 26, 2011 $75 to $100. The 1200 tach does not hook to the coil, it is induction triggered by the b/y wires in the dash harness. Link to comment
yello620 Posted May 26, 2011 Report Share Posted May 26, 2011 $75 to $100. The 1200 tach does not hook to the coil, it is induction triggered by the b/y wires in the dash harness. The wiring is the part i need to know, it was sold to me as a 620 tach, but it is a 1200 inductive pickup style. Would like to know if it works, as to not sell somebody a bad tach. Even wiring just to temporarily test it out would be nice. Link to comment
ggzilla Posted May 26, 2011 Report Share Posted May 26, 2011 If it has this loop, it's a 1200 tachometer: Link to comment
ggzilla Posted May 26, 2011 Report Share Posted May 26, 2011 face comparison, the font and colors are different: early 1200 late 1200 and 620 Link to comment
yello620 Posted May 26, 2011 Report Share Posted May 26, 2011 I have one of each of those two pictured. So the looped black/white wire going that goes from the ignition switch to the tach and then to the coil is keyed hot power right? Link to comment
