fourfiveten Posted May 19, 2011 Report Share Posted May 19, 2011 I've pulled the rear cross member from my parts car and it's ready for modding. Problem being, I gave the copy of DQ that has the article in it to the mechanic I was going to have do the welding and he lost it, so I'm hoping someone on here has a copy and could scan and PM me the article. I've called the DQ with no result and I'd like to do this mod b'fore Canby. Please help if you can. Thanx. Like it says in the title the article I need is the pennultimate cross member article Quote Link to comment
WAGON JON Posted May 20, 2011 Report Share Posted May 20, 2011 Here are some oics if this helps. http://datsun510.com/photopost/showphoto.php?photo=8005&cat=views&limit=views this one might work if you are in a pinch... http://dimequarterly.tierranet.com/articles/tech_crossmember_slotting.html http://www.datsport.com/adustable-rearxmember-kit.html http://www.datsport.com/fitting-instruction/arc-diy-kit-fitting-instructions.html http://www.the510realm.com/viewtopic.php?f=2&p=157718 Quote Link to comment
fourfiveten Posted May 20, 2011 Author Report Share Posted May 20, 2011 Thanks Jon, Sebastian, from DQ ended up getting back to me after all, so I'll be able to get the info & fingers crossed be up and rolling for Canby. Quote Link to comment
WAGON JON Posted May 20, 2011 Report Share Posted May 20, 2011 Thanks Jon, Sebastian, from DQ ended up getting back to me after all, so I'll be able to get the info & fingers crossed be up and rolling for Canby. Good deal! Quote Link to comment
Dime Dave Posted May 22, 2011 Report Share Posted May 22, 2011 I've pulled the rear cross member from my parts car and it's ready for modding. Problem being, I gave the copy of DQ that has the article in it to the mechanic I was going to have do the welding and he lost it, so I'm hoping someone on here has a copy and could scan and PM me the article. I've called the DQ with no result and I'd like to do this mod b'fore Canby. Please help if you can. Thanx. Like it says in the title the article I need is the pennultimate cross member article FutoFab sells C&B Camber Toe adjusters for $280USD/set (S&H US-$15, Canada $28). These adjusters are designed to be used with the original style rubber control arm bushings or mono-ball bushing replacements. If used with polyurethane bushings, any camber-toe adjustment from stock position will cause the bushings to bind. Range of adjustment is: 1.5 deg positive to 3 deg negative camber 1" total toe out to 1.4" total toe in Contact me at Dave@FutoFab.com (PayPal accepted) Install Link: C&B Camber/Toe Adjuster Installation Brackets Loose: Brackets Installed 1 Quote Link to comment
