b210in Posted May 5, 2011 Report Share Posted May 5, 2011 my datsun has a ca18det with matching 5speed. The car is running perfect right now. When i gun it and hit the throttle, and shift at like 7k, the gears sometimes have a hard time going in. it shifts perfectly at normal driving conditions. the tranny makes no grinding noises or old abused bearing noises. i used the stock b210 clutch master cylinder connected to the stock ca18det slave cylinder by a stainless steel line, there are no leaks from the system. i noticed that the stock slave cylinder from the b21o tranny has an 11/16's bore and the stock ca18det tranny slave cylinder has a bore of 3/4's. im thinking that the stock b210 clutch master cylinder does not have the correct capacity to properly shift the ca18det slave cylinder. those of you that have swapped an sr, ca, or ka, what clutch master cylinder have you used? also worth noting, i have no electronics connected to the ca18det tranny. i noticed that it has a lot of switches and electronic gizmos attached to it and nove are connected. could the lack of connecting these have anything to do with it? any guidance is appreciated. Quote Link to comment
ggzilla Posted May 6, 2011 Report Share Posted May 6, 2011 That's not the clutch, it's the transmission design. It is notorious for not shifting under full throttle when over 5,000 RPM. A lot of guys change the transmission to a newer design, and swap the CA front half case onto the new transmission. Quote Link to comment
b210in Posted May 6, 2011 Author Report Share Posted May 6, 2011 dam this sucks. Quote Link to comment
Farmer Joe Posted May 6, 2011 Report Share Posted May 6, 2011 well you might try some royal purple or something for your trans fluid.. other than that, i was gonna figure that it would be the synchros not working at that high of an RPM change... Quote Link to comment
