vw40life Posted April 29, 2011 Report Share Posted April 29, 2011 okay so i did a head gasket on my pick up truck and know it will not run at all i ran b4 i did the head gasket replament on it and now it will not fire up did everything like the book told me and it lost compression thank you daniel Quote Link to comment
ggzilla Posted April 29, 2011 Report Share Posted April 29, 2011 If it now has lost compression on all cylinders, probably the mechanical timing is off. Re-check the chain and pulley positions. Don't go by the marks on the chain but verify the marks on the pulleys. Quote Link to comment
izzo Posted April 29, 2011 Report Share Posted April 29, 2011 Did you clean the head surface off really good, as well as the block surface? As well as throw a straight edge on the head to make sure it wasn't warped? Id try ggzilla suggestion first. with piston 1 at TDC, the cam lobes should be at 4 and 8 oclock position. Line up tdc on the timing mark on the crank pulley then check your front two cam lobes. this will give you some idea if the mechanical timing is off Quote Link to comment
vw40life Posted April 29, 2011 Author Report Share Posted April 29, 2011 If it now has lost compression on all cylinders, probably the mechanical timing is off. Re-check the chain and pulley positions. Don't go by the marks on the chain but verify the marks on the pulleys. thanks because the truck is my daily if i hope that fixes her thank you very alot Quote Link to comment
