RatsunRailer67 Posted February 19, 2008 Report Share Posted February 19, 2008 So does anyone have any ideas on what to do for the throttle linkage from a nikko to a weber on a j13? Im not sure how to go about it with the return spring and where to put the pivot... ... ... Quote Link to comment
mklotz70 Posted February 19, 2008 Report Share Posted February 19, 2008 can't really tell what you have with it all piled together like that. Quote Link to comment
mklotz70 Posted February 19, 2008 Report Share Posted February 19, 2008 LOL! I kept thinking it looked familiar....took me a min to realize it was a J motor.....read the siggy :) This should give you a rough idea of the mani linkage. Mine had a bit different cable bracket. Your bracket will mount to the back left bolt(closest to brake m/c) and should point the cable down toward the arm with the barrel on it. The ball joint end shoudl connect up to the carb, but the arm on your carb is too far away. Not sure what you'll have to do to fix that. Might be easier to get a later model accel cable that is a lot longer. Quote Link to comment
mklotz70 Posted February 19, 2008 Report Share Posted February 19, 2008 found another angle and it was already in my photobucket. Quote Link to comment
RatsunRailer67 Posted February 19, 2008 Author Report Share Posted February 19, 2008 Thats the stock nikko carb isnt it? Ive rigged up a 32/36 weber the arm is a little farther away... I should be able to rig something up to make it work. They make an adapter for it buts its like $50 a little pricey. I figured i could make something for quite a bit cheaper... Thanks for the help Quote Link to comment
RatsunRailer67 Posted February 23, 2008 Author Report Share Posted February 23, 2008 Does anyone have any ideas? Cause for now i have it okey rigged with some bailing wire LOL;) Quote Link to comment
