pickleweasle Posted March 30, 2011 Report Share Posted March 30, 2011 Whats up guys! So I have a 79 620 auto trans and i'm wanting to swap it to a 5 speed i have a 5 speed trans from a nissan I think it was an 83 with a z engine I am sure that its a Z engine I've heard that the trans will work if you swap the bell housing but i have never heard if you can use the flywheel and clutch or If you have to use the L series parts and also is the shifter location and driveshaft the same. Thanks! Quote Link to comment
datzenmike Posted March 30, 2011 Report Share Posted March 30, 2011 You will need: A standard clutch and brake peddle with all the bolts, clips, springs and switches plus a clutch master pushrod. A clutch master cylinder. Get a new one they are cheap and saves a leaky one that needs rebuilding. A clutch slave cylinder. Get a new one they are cheap and saves a leaky one that needs rebuilding. A hard line and a flex line to join the last two together. A flywheel, preferably 225mm A clutch disc and pressure plate assy, preferably with the release bearing and collar. A clutch arm and boot. May be on the tranny you get. Rather than swapping the front case to make it fit your '79 just get a 5 speed from a 620, 290z/zx or a Maxima to begin with. The 720 tranny may be too short as well. Quote Link to comment
