Projector Diagram?
Zeusimo
Well I Got Some Projectors Cheap And Fitted Them On My Truck And Wired Them Up Using This:
But It Blows A Fuse...
Anyone Know Of A Diagram That Works?
Nothing Fancy BMW Projectors With Regular Hb4 Bulbs On A 620 :)
  • Replies 6
Make sure the fuses are correct inside the fuse box. This will be the amperage you need when you run the relays. Once you have that figured out, then the fun begins on correctly wiring the H4s
The wattage for an H4 bulb is 60 watts
(An electrical engineer will eventually correct me here...)
60 Watts / 12 volts = 5 Amps draw.
5 Amps of Draw X 4 Headlights = 20 Amps...You shouldn't be blowing any fuses with 25 Amps or 30 Amps...
