Hoosier77 Posted March 23, 2011 Report Share Posted March 23, 2011 Just wondering if the FS5W71C is the transmission mated to the s13 sr20det engines. I have a pdf of the manual for an s14 and it has that tranny in it under the manual transmission section. I need to use th enumber to tell my tranny guy so he can source me a clutch, i also need a part number for the rubber shift boot on the tranny and the slave cylinder. thanks!! Quote Link to comment
4cfed510 Posted March 23, 2011 Report Share Posted March 23, 2011 Just wondering if the FS5W71C is the transmission mated to the s13 sr20det engines. I have a pdf of the manual for an s14 and it has that tranny in it under the manual transmission section. I need to use th enumber to tell my tranny guy so he can source me a clutch, i also need a part number for the rubber shift boot on the tranny and the slave cylinder. thanks!! That is a trans that also came in the 84-89 300zx non turbo models, if that helps? Im looking for one for my vg30 swap:) Quote Link to comment
datzenmike Posted March 23, 2011 Report Share Posted March 23, 2011 Just wondering if the FS5W71C is the transmission mated to the s13 sr20det engines. I have a pdf of the manual for an s14 and it has that tranny in it under the manual transmission section. I need to use th enumber to tell my tranny guy so he can source me a clutch, i also need a part number for the rubber shift boot on the tranny and the slave cylinder. thanks!! The tranny has nothing whatever to do with the clutch selection. The clutch/pressure plate has to fit the engine flywheel bolt pattern. I have no idea what flywheel size was used on the DET at least a 240mm like an S-32 I would imagine. Our S13 and S14 only came with the KA motors so this must be an import Silvia motor? I believe the FS5W71C was the transmission used with it. Our S-13 240sx parts: Clutch arm boot.................... 30542 01S00 Clutch slave 11/16".............. 30620 35F00 through '90 Clutch slave 3/4"................... 30620 18V01 through '93 Clutch slave 3/4"................... 30620 69F01 '93 on... Tranny shift boot.................... 32862 V5001 That is a trans that also came in the 84-89 300zx non turbo models, if that helps? Im looking for one for my vg30 swap:) Yes it's the same transmission type but with a 4 cylinder bolt pattern. Also the 300zx would have a different output spline size than the 4 cyl. The FS5W71C came in 3 (at least) different lengths. Quote Link to comment
Hoosier77 Posted March 23, 2011 Author Report Share Posted March 23, 2011 since i know the engine and now im pretty sure of the tranny i can let my transmission guy knwo and then he can do the rest. I have found lots of clutches online but they are either cheap knock offs or high dollar puck clutches. Anybody ever use ACT? Quote Link to comment
