FS5W71C
Hoosier77
Just wondering if the FS5W71C is the transmission mated to the s13 sr20det engines. I have a pdf of the manual for an s14 and it has that tranny in it under the manual transmission section. I need to use th enumber to tell my tranny guy so he can source me a clutch, i also need a part number for the rubber shift boot on the tranny and the slave cylinder. thanks!!
  • Replies 3
That is a trans that also came in the 84-89 300zx non turbo models, if that helps? Im looking for one for my vg30 swap:)
The tranny has nothing whatever to do with the clutch selection. The clutch/pressure plate has to fit the engine flywheel bolt pattern. I have no idea what flywheel size was used on the DET at least a 240mm like an S-32 I would imagine. Our S13 and S14 only came with the KA motors so this must be an import Silvia motor? I believe the FS5W71C was the transmission used with it.
Our S-13 240sx parts:
Clutch arm boot.................... 30542 01S00
Clutch slave 11/16".............. 30620 35F00 through '90
Clutch slave 3/4"................... 30620 18V01 through '93
Clutch slave 3/4"................... 30620 69F01 '93 on...
Tranny shift boot.................... 32862 V5001
Yes it's the same transmission type but with a 4 cylinder bolt pattern. Also the 300zx would have a different output spline size than the 4 cyl. The FS5W71C came in 3 (at least) different lengths.
