oil pan & pu tube
  • Replies 8
The Z24 is a truck motor so a Z24 oil pan won't be a front sump. A Z20E or S or Z22E car oil pan will fit the Z24 and work just fine.
Is this an S110 second generation 200sx? I ask because a Z24 swap makes sense. If into a first generation 200sx you will need more than an oil pan.
Need more info.
What vehicle is it going into? Year?
To ID the motor look just below the #2 spark plug on the driver's side of the block. May need a flashlight and wire brush to see it.
Hmmm the S12 ('85 200sx) never came with a Z series motor so this must be a swap. Need much more info.
Does it have a matching Z series transmission?
Do you have the Z motor mounts for it?
It's a swap. old asphalt race car now going to the clay ovel, sold car but do not want to give up any L motors. I'll make mounts and change bell, later when the rookie learns to drive Ill put 219 head and change bell and motor mounts back.
